I heard somewhere that some connectors (composite, s-vidéo, yuv, dvi, hdmi) have a limited resolution support.
Here's a list of the most popular connectors with
with their (supposed) maximum resolution (tell me if i'm wrong) :
Composite : 380i (maybe 220i, but it seems to be a small value...)
SVideo : 400i
YUV : 480i
HDMI : 1080i
DVI : 2400I
Thanks for your help guys.
SVideo : 400i
YUV : 480i
HDMI : 1080i
DVI : 2400I -
Originally Posted by masterpingouin
Analog:
Composite PAL or NTSC:
VHS: ~352x480/576i
Studio: ~800x480/576i
S-Video: PAL or NTSC
S-VHS: ~450x480/576i
YUV : 720x480i, 720x576i, 1280x720p, 1920x1080i plus 1080p in studio
VGA: Computer "Vesa" resolutions.
Digital:
DVI-D: 480i, 576i, 720p, 1080i plus all the computer "Vesa" resolutions
HDMI : 480i, 576i, 720p, 1080i, 1080p
Serial Digital: 480i, 576i, 720p, 1080i, 1080p, 2kx4k, 4kx4k
Resolution is only one measure of video picture quality. Signal to noise and bit depth are also important.
right angle SATA connectors
By rallynavvie in forum ComputerReplies: 22Last Post: 31st Aug 2009, 06:42 -
philips dvp5992 displays "Video Resolution not Supported"
By mike69 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 30th Dec 2008, 09:17 -
cutting off unneeded psu connectors
By zeppage2 in forum ComputerReplies: 4Last Post: 2nd Nov 2008, 16:58 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07 -
Native Resolution not supported
By Bizzen in forum ComputerReplies: 10Last Post: 17th Oct 2007, 04:45
